Group Buy H&r Spacers
6.6K views 20 replies 11 participants last post by  Alloy-Wheels.ie
Thanks to those who registered their interest in the feeler thread.
I have listed below our prices on hubcentric H&R wheel spacers. The spacers are priced per axel.
For the purpose of this group buy I will give the following discounts based on -
10 members - 10%
20+ members - 15%
(Price Example based on 11 Members - 1xDR 30mm with 43mm boltsx10 =€130 - 10% =€117)
DR System:
10mm (05mm per side) - €70
16mm (08mm per side) - €80
20mm (10mm per side) - €95
24mm (12mm per side) - €100
30mm (15mm per side) - €105
40mm (20mm per side) - €115
DRA System:
40mm (20mm per side) - €140
50mm (25mm per side) - €150
60mm (30mm per side) - €160
Bolts/Nuts:
Up to 45mm x8 - €20
Up to 65mm x8 - €24
Up to 45mm x10 - €25
Up to 65mm x10 - €30
Note: All DR Systems require longer wheel bolts which have to be ordered separatly. We will need to know the measurement of thread on your current studs/bolts and if its cone or radius. I have attached two images below so you can see what this means.
If you can resgister your interest in this format please -
1. YOUR NAME - VW Golf MK4, DR 30mm (the kit you require), Radius 28mm (your current bolt configuration).
Please Note: Nationwide Recorded Delivery - €15
Keith
Its not advisable to have 5 locking nuts holding your wheel on.
The majority of locking nuts are made from a low tensile metal.
A better idea would be to have normal wheel bolts and a good set of locking nuts.
Keith
QUOTE (Alloy-Wheels.ie @ May 15 2008, 09:28 AM) <{POST_SNAPBACK}>Its not advisable to have 5 locking nuts holding your wheel on.
Keith
its what came with the wheels.......its hard to explane,tere not lock nuts but all need an adapter to get off
QUOTE (Glenn @ May 15 2008, 09:32 AM) <{POST_SNAPBACK}>Would you have a price for 20mm thick 5x100 - 5x120 adapters?
The 40mm total track DRA spacers 5x100 to 5x120 are available.
They are priced as above.
Keith
QUOTE (razor @ May 15 2008, 11:04 AM) <{POST_SNAPBACK}>its what came with the wheels.......its hard to explane,tere not lock nuts but all need an adapter to get off
Ah get you now sounds like tuning bolts to me.
Keith
1. Trevor - Octavia RS mk2, DR 20mm, standard VAG Radius taper.
2. Trevor - Golf GTI mk5, DR 20mm, 28mm Cone taper for BBS. Current wheels BBS CH (need 38-40mm bolts)
3. Trevor - Golf GTI mk5, DR 20mm, 28mm Cone taper for BBS. Current wheels BBS CH (need 38-40mm bolts)
4. Dec (Passat 130) - Golf GTI mk4, DR 20mm, 28 mm Cone Taper for BBS. Current Wheels BBS RC
and bump !
QUOTE (Passat130 @ May 30 2008, 11:18 AM) <{POST_SNAPBACK}>1. Trevor - Octavia RS mk2, DR 20mm, standard VAG Radius taper.
and bump !
I should be picking mine up off Andy on Sunday. Thanks Keith.
QUOTE (MaloR @ Jun 2 2008, 09:15 PM) <{POST_SNAPBACK}>What mm should you be putting a golf gt my wheels are 17 and seem a bit lost in the arches, is there any down sides to them, probably sound like a granny but are they safe yes? Would they cause different handling would i also need to change the wheel nuts yes?
It would be advisable to measure the clearance with your current wheels to the arch. I'd say 10mm all round would be perfect on a MK5 with 17's.
As for safety - all H&R spacers are TUV approved. This means they have been tested to comply with various safety regulations in Germany.
Your handling will not be negatively effected by the spacers.
If you have any more questions let me know.
Keith
QUOTE (Alloy-Wheels.ie @ Jun 4 2008, 12:46 PM) <{POST_SNAPBACK}>It would be advisable to measure the clearance with your current wheels to the arch. I'd say 10mm all round would be perfect on a MK5 with 17's.
Keith
My mk v has coilovers and H&R spacers all round .I have 20mm on the front and 30mm on the rear without any rubbing on 17 or 18 " rims even with the car running very low .
QUOTE (Alloy-Wheels.ie @ May 12 2008, 10:21 AM) <{POST_SNAPBACK}>
10 members - 10%
20+ members - 15%
DR System:
DRA System:
Bolts/Nuts:
Up to 45mm x8 - €20
Up to 65mm x8 - €24
Keith
I will be up for a set of 20mm (10mm each side) but just need to confirm few things.
I will be getting at least one set
QUOTE (Trevor @ Jun 6 2008, 12:23 PM) <{POST_SNAPBACK}>Thanks Keith. Arrived today. Quality stuff. Thanks.
Thats great Trevor. Thanks.
Keith
Are these prices delivered?
(original posted edited to show delivery)
We offer delivery with tracking on the spacer kits for €15 nationwide.
Keith
I'll be closing this offer off this Sunday the 6th of July.
If anyone is debating a suspension kit or coil-over kit let me know . Im going to run a special discount on both when this finishes.
Keith
