Mk1 Gti Drive Shaft
1.3K views 6 replies 3 participants last post by  sherlock
hi lads im just looking for another point of view. I have a 1.6gti mk1 and the inner cv on the passenger side(the short one) has gone,i took out the driveshaft and it looks like the shaft is too long and has been hitting the output on the gearbox.The end of the shaft has actually mushroomed a bit.(technical term?).I think a longer shaft has been used mabye off a mk2 if so is there anything other than a mk1 i can get a shaft off?
thanks in advance
#3 · (Edited by Moderator)
i mite be able to get a pic in a few hours.see it was built from a 1300cc shell to a rallycross car so i dont know wheather there the write shafts used or not d,ya get me?
edit is there even a difference with mk2 shafts and mk1s?
oh ok its not the cv joint i think is moving its grand and is held by its circlip. But the end of the shaft has definatley come into contact with the output of the gearbox because you can see the marks on the output and the shaft,the end of the shaft has actually worn in so bad the cv wont slide off and the tip of the shaft is visibly bigger. Sorry if im not making any sense il try get a pic in a little while.
i never actualy noticed if the cv was compressed back.But i think i have another shaft and a new cv to put in and il see how she gos.
thanks for the help lads
