B3 Shocks
1.3K views 4 replies 3 participants last post by  BLZEEDUB
anyone know what other late 80's earley 90's vag motor has the front shocks with the steering pickup on the strut under the spring seat.
get'n it hard to find a set of coilovers to suit
#5 · (Edited by Moderator)
Is it the B2 Passat (82-88) or the B3 (88-93) passat you are referring to/need info on?
The B2 has the steering 'arm' attached to the strut/below the spring cup; B3 has the conventional; steering arm off the upright' arrangement...
Mk3 Golf struts will fit straight into a B3 passat.
As for B2; AFAIK some audi 80 (mid eightes) coilovers n lowering springs will fit (from memory of when i briefly had a B2) -there lots of info on the B2 era Passat on 'ukpassats' forum...
