288mm To 312mm?
3.6K views 30 replies 11 participants last post by  Alloy-Wheels.ie
Would there be much of a difference to braking? I know i need new carriers, pads and discs.
put some brembo disc on rob,i had them on my 312's on the van they were great,you can get some of bager5 that a cross drilled too,ment to be the dogs. OE disc are okay nothing great,as for pads theres so many to chose from, Pagid blue, EBC yellows, ferodo, brembo....etc etc etc
#17 · (Edited by Moderator)
The OEM discs and pads are 100% competent up to about 220/230 Rob the max you are going to be running is 130 plus a remap i.e 170 so keep the costs done and keep it OEM.
QUOTE (razor @ Jul 1 2009, 11:26 PM) <{POST_SNAPBACK}>its never a bad thing to uprate ur breaks though man
This i know,but for general road use the are more than capable.
Another vote for EBC grooved and dimpled, i matched mine with green stuff pads. I think i demonstrated their stopping power when you had my car on vagcom?
QUOTE (Shane @ Jul 1 2009, 11:25 PM) <{POST_SNAPBACK}>The OEM discs and pads are 100% competent up to about 220/230 Rob the max you are going to be running is 130 with a remap so keep the costs done and keep it OEM.
He is running at 130 already before the map
QUOTE (Flano @ Jul 1 2009, 11:32 PM) <{POST_SNAPBACK}>He is running at 130 already before the map
I meant 130 plus a remap i.e 170 odd -- check the edit
i'm not that stupid.
288 rob
I went down the upgrade route instead of larger discs. Better again as was said bigger and upgraded would be a great job I would say?
