A week or so ago, i got into the car to come home from the shops and it wouldn't start.
Sounded like it wasn't getting fuel, so took off the top fuel line and sure enough, there was nothing. I assumed it was the fuel pump.
My brother came over with the tow rope and the old mans car so i didn't have to leave it outside the shops... after a pull the car started and drove home (15mins).
The next day, it started fine but it was only to move it out of the driveway, and put it back in. The following day, it didn't start again.
Still thinking it was the fuel pump, i plugged in VAGCOM just to see if anything was throwing up an error. VAGCOM said there was no signal, yet the green light on the lead was lit. I tried the laptop in another car - so that was working. I went to the fuses beside the steering column - all OK.
BUT... the three fuses (30a) on top of the battery had MELTED. The fuse-holder had bubbled and most of it melted. Fuses, obviously, blown. I got a 30A fuse and made sure it had contact.. VAGCOM then connected to the car - and no errors. But it still wouldn't start...
I got a new fuse-block today and put it on, but still nothing. There is definitely fuel getting to the engine, and it is definietly getting a spark.
Any ideas??
Any ideas??
