Water-methanol Injection, Wmi
23K views 57 replies 15 participants last post by  Ev'0
Wow robbie, just read through all this and it's one of the most interesting thread I've read on here. It's a system I hadn't heard of before but it seems to have given you great gains, the spacer with the injector port seems to work a treat too!
I have a question about using the water methanol mixture, why is it just water/methanol that's used in these systems? there are a lot of other alcohols which have more suitable properties.
I was just thinking of water and acetonitrile. A 70:30 mixture of water:acetonitrile for example produces an endothermic reaction almost instantenously, cooling the mixture to about 5 degrees. It has somolar properties to methanol in that it's a volatile liquid on it's own but would be relatively more stable than the methanol on it's own.
Just wondering has anybody experimented with this mixture? In theory, you would be producing a water, solvent mixture with fairly similar properties to the water:methanol, but once they're mixed, the temperature of the water:acetonitrile would be much more cooler.
Second thing I was curious to know is would having multiple ports on brian G's spacer help in atomisation? having 2 regulated injectors mounted opposed to each other for example?
Anywho, top work dude!
