Vag 170 Pd Engine Fault
4939 Views 31 Replies 16 Participants Last post by  morch_66479
Hi all,
I'm just starting this thread to try and raise awareness from this side of the pond regarding the defective Siemans injector system fitted to the 170bhp 2.0 16V Tdi PD engines in various Volkswagens,Audi's,Skoda's and Seat's.
Just a brief explanation for anyone not affected. AFAIK the Siemans injectors were fitted to this engine (PD) to bring emissions in line with EU regulations. These injectors fail regularly and commonly and can be very dangerous. Once the injector goes down the a very brief warning -Engine Fault Workshop' appears on the dash and then the Ecu completely shuts down. From the time the problem is diagnosed you have about 2-3 seconds before you lose all power including no steering and no brakes. If you happened to be tipping along at 100 kph or overtaking this could have catastrophic results as you can imagine! The cost involved in this repair is huge. One new injector is E600 + VAT. Also when the injector goes down it dumps a load of diesal into the cylinder which in turn completely blocks the DPF. As a forced regeneration of the DPF is not reccommended by manufacturers the only fix is a new filter at E1000+.
However this is not about cost or trying to blag free injectors or DPF's. It's about raising awareness of this potentially fatal flaw on these cars which to this point VAG completely disregard and only put down to 'coincidence'. It's not good enough.
There's a campaign being started on virtually every VAG forum now so as to try and bring this to the attention of VAG and to show that this is not a 'coincidence'
I would really appreciate if anyone affected by this would post here with maybe a brief explanation of how it happened and any repair costs incurred.
Even if you're a VAG owner and you're not affected by this it would be interesting to hear you're comments?
This is just a link to my specific problem which happenend only this week..
http://vagdrivers.net/forums/index.php?showtopic=62376
This is a link to the Briskoda thread....
http://briskoda.net/forums/topic/197422-va...es-vosa-action/
Seat cupra link...
http://www.seatcupra.net/forums/showthread.php?t=268033
VAG Romania...
http://vwforum.vwforum.ro/topic/52745-inje...60#entry1553038
Any help on spreading the word on this would be appreciated lads.
1 - 20 of 32 Posts
Same thing happened to a lad I know with his '07 A4 (170bhp, same as yours). Scary bill, crazy really on a car that's still relatively fresh!
Are these CR engines or PD? I know you said PD but just to be sure
Only PD Steven.
I've had 2 go down between March and September of last year, got all four replaced second time round and been fine since. This business of coasting to a hault with no prior warning is the worst part (even worse than the mad repair bill) especially if you happened to be in the middle of an overtake!
Sorry to hear about this Enda. Hope you get it sorted without too much expense.
Had 2 go as well back at the end of last year, lucky enough i was in cruising along an empty motorway. Led to serious Dpf problems ending in the Dpf delete.
Outrageous stuff to be happening to quite new cars!
2
QUOTE (KevC @ Apr 8 2011, 12:08 PM) <{POST_SNAPBACK}>I've had 2 go down between March and September of last year, got all four replaced second time round and been fine since. This business of coasting to a hault with no prior warning is the worst part (even worse than the mad repair bill) especially if you happened to be in the middle of an overtake!
Definately replacing all 4 and a dpf delete is the only job. I just think it's a disgrace to have to spend 2+ grand to leave a 2007 car a good car! And all because the manufacturers use faulty parts!
The situation I'm in is that I am just not in a position to spend that amount at this moment and so because of this I will probably be forced to sell the car. I can't afford either not to be able to drive anywhere not knowing whether the car will just stand up on the road. It's a shame because I really did love the car and the wife is gutted too
Ah well...looks like it'll be a bit of a downgrade for a while
Whats to stop the newly fitted injector(s) from failing 3or4 years down the line?
Absolutely nothing. Around 50-60K seems to be the shelf life of these Siemans injectors.
QUOTE (endakillian @ Apr 8 2011, 02:37 PM) <{POST_SNAPBACK}>Absolutely nothing. Around 50-60K seems to be the shelf life of these Siemans injectors.
Or 32k & 40k ish in my case!
Is there no alternative to using the siemens ones? is there not a modified one?
2
QUOTE (KevC @ Apr 8 2011, 02:42 PM) <{POST_SNAPBACK}>Or 32k & 40k ish in my case!
Seriously!?
Thats shockin'!
QUOTE (Dallan @ Apr 8 2011, 03:06 PM) <{POST_SNAPBACK}>Is there no alternative to using the siemens ones? is there not a modified one?
It's not something i've actually looked into tbh but i would seriously doubt it for the simple reason that this is such a common problem and has affected so many people and to date ive never heard of any other fix other than replacing like with like. There could well be something out there Dallan-i just wanted to raise the safety issue (or lack of it!) here and VAG's blatant disregard for customers safety and lack of acknowledgement of any issue at all.
May be worth looking into though
Would pd140 injectors with a bit of custom mapping fit?
QUOTE (kevinm @ Apr 8 2011, 11:51 PM) <{POST_SNAPBACK}>Would pd140 injectors with a bit of custom mapping fit?
There pretty expensive too and not much better to be quiet honest!!
QUOTE (KevC @ Apr 8 2011, 11:52 PM) <{POST_SNAPBACK}>There pretty expensive too and not much better to be quiet honest!!
Do they cause trouble too?
QUOTE (kevinm @ Apr 8 2011, 11:59 PM) <{POST_SNAPBACK}>Do they cause trouble too?
We'll I've had conversations with a good few people who were in trouble with them anyway!
Martin on here (Morch) had his fail on his 06 Passat. If / when that happens I'l be one pissed off VAG driver . Went mental over the DPF issue so this could lead to a stroke altogether !!!!
I have 1 injector fail myself last year in October and it cost me all the repair 850 euro with a second hand injector from a member here Kevin (KevC). I was at the traffic lights when this happen so just causing some obstruction for other drivers. So far I clocked over 10 thousands km after repair and seem to be fine but now I am getting concern about this because I am driving abroad in a couple of weeks and I don’t want another injector to fail while I am over. The mileage now on my vrs is 183 thousands km.
1 - 20 of 32 Posts
