Tuning A 1.9d
2 reading
4.2K views 17 replies 10 participants last post by  vento 19
Well all was just wondering what could I do to get a bit of power from a 1.9d vento without loosing too much mpg...
any ideas on what i can do?
is it possible to turbo it maybe?
injectors?
pump?
Cheers in advance
you could shim out the govenor inside the pump, along with 'more air' - an induction kit/filter, and turning up the fuel for some extra oomph; fuel consumption will go right up, but it will be a tad quicker - no real noticeable difference in top end TBH.
Another alternative is to 'pillage' an AAZ for its pump and low pressure turbo (ko3) - if you look in 'parts for sale' J.LYONS (i think...) had an AAZ for parts; had a crank problem, so would be an ideal parts donor...
QUOTE (RetroMk2 @ Jan 18 2012, 08:33 PM) <{POST_SNAPBACK}>You can play with the fuel pump alright. Turn it up until it smokes on idle then turn it back a quarter of half a turn. They get a small bit nippier
yeah ill prob adjust the pump a bit alright smoke and poke
QUOTE (BLZEEDUB @ Jan 18 2012, 08:47 PM) <{POST_SNAPBACK}>you could shim out the govenor inside the pump, along with 'more air' - an induction kit/filter, and turning up the fuel for some extra oomph; fuel consumption will go right up, but it will be a tad quicker - no real noticeable difference in top end TBH.
hmmm that could be the plan to follow alright... would the aaz turbo and manifold etc fit
QUOTE (Quinncey @ Jan 18 2012, 09:24 PM) <{POST_SNAPBACK}>yeah ill prob adjust the pump a bit alright smoke and poke
i sold that set up , what year is your car it may be set up for a turbo as standard
I have an AAZ turbo and manifold for sale here. Might even have a Pump as well
QUOTE (Quinncey @ Jan 18 2012, 09:58 PM) <{POST_SNAPBACK}>its a 96 engine so it is would it be set up for turbo ????
it should be if you check the back of the block near the rear driveshaft and see if 1.9D/TD is on the block
Hi there.
Won't have td stamped on block afaik. Only 1.9d
Absolutely pointless screwing pump etc on a n/a.
You should be able to fit td pump and turbo and exhaust and inlet mani with relative ease.
this would give you 30-40% increase in power.
All said, you'd fit a td setup handier than modding your current setup.
Cheers
QUOTE (vento 19 @ May 13 2012, 01:17 PM) <{POST_SNAPBACK}>When you say may be set up for turbo what exactly do you mean? If it is what all would I need to buy and is it just a bolt on job? "1998 1.9d vento Atlantic"
Well man sorry for the delay been busy lately ill get back to you tomorrow about those bonnet lifters
QUOTE (Jimmy Diesel Junior @ May 13 2012, 09:14 PM) <{POST_SNAPBACK}>Hi there.
Cheers
Yeah it is stamped on my 1.9d block anyway but maybe there is a diff in the 96 and 98 ones??? so a gtd pump turbo and exhaust would bolt straight on too yeah??
if the aaz stuff fits is it an inlet and exhaust manni, turbo, oil lines, and possibly a sump??? am i missing anything??
i no it would be way easier to get a td but no fun in that
Cheers for info lads
the oil drain off for the turbo on an AAZ is on the lower part of the block; to get round this, you could use a 1.6TD/GTD sump and drain line, and to make life even easier, a turbo off a 1.6td/gtd...
or, if you can weld, you could 'add' an oil drain off tube (and 'fitting') to the present sump to facilitate the oil drain off line for whatever turbo you intend to use......
#18 · (Edited by Moderator)
So that's all that needed is:
Td fuel pump
Turbo
Td sump
Td inlet and exhaust manifold
Oil lines
If I got a full td engine out of a mk3 golf is it a matter of just lifting old out and dropping new in or will I need to make changes for Td engine (anything at all)?
or if i got a TDI engine is it a matter of just lifting old out and dropping new in or will I need to make changes for Td engine (anything at all)?
@Quinncey cheers man!!
