Rob's Loft!
21K views 122 replies 41 participants last post by  dj.humps
All parts are collection only (or plus postage)
i'm located on the kildare wicklow border.
contact info:post here, pm or 0857610453
Mk1
Wishbone-drivers side x2 €20 each
Wishbone-passenger side €20
1.3 springs rear € free collected
Gti Rabbit front calipers €40 for pair
Gti rocker cover €15
Gti 4 branch manifold waiting collection
Gti rear springs €40
1.3 air box and breather €free collected
Rear spats-pair €20
Bonnet prop x2 €5 each
5dr sill trim €5 per piece
Swage line trim-full set 5 door €40 for set
A pillar trim €10 per side
B pillar trim €10 per piece
C pillar trim €10per piece
Rear view mirror €15
Gti inlet pipe €15
Sun visor- pair €15 each
Inside door handle x3 €20 each
1.6 oil pan €20
1.6 dizzy drive €50
1.6 crank €free collected
Gti rabbit radiator €75
Big block radiator €50
Gti radiator and cowel €50
1.3 fan cowel €20
(Carb engine) petrol tank €60
Wing drivers side-filler near the bottom €30
Rabbit front and rear bumper €60 for the pair
Inner wing-ds €30
1.3 radiator €20
Gti steering wheel with centre €50
Wolfsberg steering wheel €50
Bonnet €150
Boot lid €150
S1 clocks, black face €100
NEW rear shocks €75 for pair.
S1 rear lights-pair €175 for pair
Centre console €50
Boot ram €20
Bonnet ram €20
Steering column trim €20
Dizzy x2 €40 each
Big block cam sprocket €15
Indicator stalk €15
Dizzy cap with leads €20
Water jacket-front of head €free
Gti metering head cap €15
Coolant bottle- no sensor €20
Coolant bottle-sensor €25
Washer bottle x4 €10 each
NEW front shocks €75 for pair
Front engine mount €15
Side engine mount €20
1.3 gearbox mount €free
1.5 Head €30
Wiper Mechanism €25
#2 · (Edited by Moderator)
MK2
Mk2
1.6 short drive shaft x2 €20
1.6 rear springs €free
1.6 exhaust manifold €20
Rear lights standard €30 pair
Jetta rear lights €10 each
Master cylinder €25
Speaker shelves €25
Front left hub €40
Timing belt cover €15
Boot lifter €15
B pillar trim
C pillar trim
Sunvisor pair €15
Drivers door mirror €25
Rear seat belt x2 €15
Front seat belt x2 €15
Door seals x2 €20
Back window seal €20
Lower glovebox €20
Slam panel x2 €15 each
Headlights x8 €20 each
Small front bumper €40
Jetta grill €25
Rear bumper frame
Pair of wings €40 each
Jetta bootlid x2 €35 each
Set of doors---5dr €40 per door
Bonnet x3 €60
C pillar trim
steering column trim
Front 1.6 engine mount
Altinator
Wiper Mechanism
#4 · (Edited by Moderator)
Mk4
1.6 springs €25
Headlight switch with foglight switch €25
1.6 throttle body (brand new) €200
1.6/1.4 Starter €50
1.6 flywheel €50
set of front hubs (new bearings in them) €50 each
front calipers €75 each
boot lid €35
passenger wing €20
doors-right (2 door) €50 each
rear bumper €80
loads of interior trim
carpets €30
roof lining €40
sunroof €60
any pics of the mk1 4 branch
also will the mk4 headlight switch fit a 99 transporter
have you a contact number
