QUOTE(Dirty1 @ Nov 12 2006, 10:22 PM) [snapback]39539[/snapback]
Ok, you can fit any porsche wheel you want it just depends on how deep your pockets are!
Do you have an idea of the style of wheel you want to fit, the type of look you are going for? e.g: Cal, German, Custom, Resto-Cal, hoodride, Oldskool looker, Race/Drag look, etc, etc
Next is are you going to lower the car? Technically you must because it crime punisable by death, not to lower a bug, and the syle police will be out in force!
Then how low do you want to go?
Then you start getting into whether you wanna run disks or narrow your beam!!
The whole look of a car depends on choosing the right wheels, but that alone is no good without the right stance! The whole Hoodride trend proves this, shitters can look hard as .... just because they stance is right!
You have a 71 bug, thats 4 stud!, you wont be able to run BRMs, Sprints etc coz theyre 5 stud!
A 4 stud VW is 4x130 PCD, a Early bug is a wide five, 5x205 PCD
Porsche stud pattern is 5x130 PCD.
Late bays on, up to the T4 use a 5x112 PCD, thats the same as Mercs, bigger Audis and Passats but gives van owners a great selection that the never seem to take advantage of???
The cheapest way to fit Porker rims is to drill your hubs, but this isnt nessesarily the safest! Next up is you can by adapters, these are mostly TUV approved and safe but widen the track and may effect clearance.
Third is to fit disks, but then your into money but will have a cool set up!
Disks can be bought in any PCD!
Usually with bugs etc you will be looking to run a skinnier rim up front, but again that depends on the stance you want!
Check out
www.machine7.com
www.coolairvw.co.uk
www.streetstyleandpower.com
Theyre nearly all doing conversion kits these days!
Also go onto www.volkszone.com thats a great resourse for info!
Are you looking at Fuchs, Cups, Cookie cutters or Gas Burners? Fuchs are very common and must be polished IMO, Cups only suit big motored cars! You can now get 4stud gas burner replicas.
Check out the sites!
Good advice.
They do 4 stud BRM & Sprintstars replicas now, although granted they do not look as good as their more original 5 lug counterparts. I have a set of Riviera's if interested, but they could do with refurbishment to be honest.
