Have a 02 PD130 Golf "GTTDI" with a 6-speed box. 130k miles on the engine. Engine code ASZ.
Engine turned over when still in car but not started. Timing belt doesn't apear to have jumped. No oil/water leaks & no holes in block.
Owner informed me that it has remapped/chipped ecu. Not verifed but due to suspicious cable ties found on removal, it would appear it was out at some stage.
PD130bhp ASZ Engine- €400
PD130bhp Turbo- €250
6-speed diesel gearbox- €400
Steering rack- €100
ECU- €250
Standard Airbox- €40
Also available are:
Clocks, steering column, master cylinder & servo, switch gear, 4 brake calipers/carriers set up.
Engine loom is still in shell at the moment but going to get binned. If anyones interested in it, contact me ASAP.
Cheers, Donie.
Steering rack- €100
ECU- €250
Also available are:
Cheers, Donie.
