Paddy's Mk2 GTI +CE2 = ABF
57K views 342 replies 63 participants last post by  paddy_cl
the rear panel needs to be replaced, (ordered)
a full respray aswel
puttin mk4 calipers on it, (mk3 ones now fitted)
full service (done also)
needs door cards (done also)
needs a motor for the n/s electric window
needs a full exhaust system
all original wheels are with it also
pics are from the phone so not perfect
92k miles,
electric windows
sunroof
central lockin
immobiliser
any of the above standard??
sure wat more do ya want with 1400euro
more to add,just not in the form,BIG HANGOVER
yeah not too many of them around at all in this colour
yeah ill have to replace the drivers seat as the bolster is worn
can i just replace the sponges on the passenger seat and also is the like a kit you can buy to replace the cloth on the seats???
indeed and i am, cant wait to get started on it, by the way conor my bro absolutely loves your gtd
Small bumpers and 16v - all good !
Good luck with project.
small update just fully serviced fluids and belts, getting it next weekend when i go home
then weld in a new rear panel to eliminate the rust on it, will get pics up of the progress,
then the full re-spray
#11 · (Edited by Moderator)
right another update so far.
stripped put the interior and started poking around the floor to see how bad it was and i ended up with......
1st pic....passenger side foot well
2nd pic....passenger side inner sill
3rd pic....driver side foot well
4th pic....driver side inner sill
and so tommorow the angle grinder comes out along with the welder, the rear panel wont be done till monday as the replacement part is delayed
more pics tomorrow evening,or the next evening
QUOTE (paddy_cl @ May 13 2008, 07:15 PM) <{POST_SNAPBACK}>right another update so far.
good luck with the project. i've seen/driven a lot worse than that. cut it all out, weld in new bits, paint with zinc182, seal it and finally paint it. have you looked underneath the car???
QUOTE (irishvdubber @ May 13 2008, 08:10 PM) <{POST_SNAPBACK}>. cut it all out, weld in new bits, paint with zinc182, seal it and finally paint it.???
yeah going to be doing that tomorrow, god loves fas, all the equipment for free,
gonna treat any rust with that stuff out of halfords ''kurust'' then weld in new panels and body schultz the inside and out.
QUOTE (irishvdubber @ May 13 2008, 08:10 PM) <{POST_SNAPBACK}>have you looked underneath the car???
yeah the beams could all do with a rub from the grinding wheel(abrasive) and schultz also
inner and outer arches to be treated this week also, there not too bad
QUOTE (Newtown Mk1 @ May 13 2008, 09:38 PM) <{POST_SNAPBACK}>(the DEAD one).
pat.
haha thats a good one. brought a smile to my face
QUOTE (Newtown Mk1 @ May 13 2008, 09:38 PM) <{POST_SNAPBACK}>Just cut up the old jetta in the back ground, they make good repair pannels. Mind the dash/glass when you are using the grinder. Best of luck with her. keep the pics coming.
pat.
yeah gonna do that if the floor is fuc**d, otherwise just patch it up and schultz, i have a fire blanket for the dash and thick brown paper for the rest of the interior(whats left of it)
more pics from today, bits cut out and ready for welding plates in tomorrow
the white is rags underneath to show up the holes cut out
look what i found when i stripped the arches
its at the end of the passenger sill at the rear
sure i havemost of the work done now and its a campaign model, im doing it in fas so its only costing me time, a clean shell is how much and then changing EVERYTHING else over is a lot more work i would think?
QUOTE (Bohall @ May 15 2008, 09:11 AM) <{POST_SNAPBACK}>With that amount of rust i'd personally not persue the repairs on the shell.....I'm sure other lads will agree with me on this.
bit late for that now haha most of it done along with a bit of flushing also
the other side tomorrow then brush the sealer over it, sure im getting paid to do it in fas so all its costing me is time.
materials are free and sound deadening all free like....
