engine and box bolted together, new mk4 gti clutch was fitted to the mk4 dual mass flywheel, we plan to replace it with a g60 flywheel and clutch in the future, that trolley trev robbed from some supermarket comes in very handy when fitting engines!
engine and box in place, new g60 front rubber mount was used and an O2O front mounting bracket was modified to fit , the block is thicker where the starter bolts pass through and it makes the mount sit about 10 to 15 mm too far to the drivers side, the cam pulley sits very close to the master cylinder i loosened the servo and slid it over and gained a bit more clearance, im told a 10mm spacer undet the drivers side engine mount gives loads of room.
the metal bottom sump gives a lot more ground clearance than the alloy one its an inch or more shorter and uses a shorter oil pick up pipe and turbo oil drain pipe. see how the bottom of the sump is level with the crossmember
this is the seat leon down pipe, its cut just before the cat and it actually bolts in to place as it is but its too close for comfort to the steering knuckle and needs to be modified.
