QUOTE (mcfudge @ Nov 28 2008, 04:03 PM)
<{POST_SNAPBACK}>any cradle to charge the phone
You can buy the cradle's separate but you can charge the phone without it, the lead that come's from
the box to plug into the cradle will also fit most nokia phone's
QUOTE (macca @ Nov 29 2008, 02:10 AM)
<{POST_SNAPBACK}>Do you need to install the speaker unit or will it run through the existing speakers? also, how much "chopping" is needed to wire it into an OEM radio(gamma)?
You do need to use the speaker unless you buy a mute lead, Theese can cost €50-€70
it depend's on your car there are load's of different lead's available
They will work on any phone that has bluetooth
They are easy to install
just 4 wire's
Earth
Acc power (power only when key is on in ignition)
constant power (^^ I alway's join theese 2 together)
radio mute (All this does is send an earth to your radio when you get a call which inturn mute's the radio)
you can find where the mute goes by earthing a wire and trying it in the Pin's at back of radio until radio mute's
