1 - 12 of 12 Posts
QUOTE (wwpassat @ Mar 27 2006, 01:33 PM) <{POST_SNAPBACK}>while checking around the car as i have test today at 4pm in deansgrange i discovered a split in the cv boot on the driverside of my passat can someone please tell me if it is as above direct or visual fail
many thanks
simon
its a def fail .
If you're asking is if it's a visual item that will be retested for free, I wouldn't think it is coz they will have to put it back on the ramp to look at it.
Discussion Starter · #6 ·
FAIL
CV-BOOT frayed/cut
SIDE LAMPS color incorrect/different
not bad me thinks for a car that i just let through considering it has illegal plates and the belly pan is held on with cable ties ,so all in all im not too dissapointed ,will get the boot done get it re tracked change bulbs and drive her on ,
1 - 12 of 12 Posts
