i have brembo 4 pot callipers and 305x28mm disks from an ibiza cupra, im using a set of mk2 16v front hubs with vr6 centres and outer cv joints changed to vr6 ones also to suit the larger spline inside the vr hub centre, if you want to keep the abs then you need to cut off the abs sensor mount and weld it back on in a different location as the abs encoder ring on the vr hub is not close enough to the sensor
the front wheels are BBS RS301 7.5x17 et33, they have a lot of brake clearance inside them as the wide track suspension set up has the callipers mounted further out then the narrow track type, my front hubs are narrow track just with the vr hubcentre, i redrilled the pcd in the disks, the wheels barely clear the calliper, i put a 1mm shim between the calliper mounting bracket and the hub.
