Well the bottom bolt is the easiest one to get at but still a lot of work. You will need to take off the engine mount bracket, which will probably mean removing the timing belt. Then you have 2 options, try to drill it and use a stud remover or else try and weld something like a nut onto the top of it to get it out that way. Either way it's not a nice job to have to face.
