Mk2 Polo Engine Swap?
18K views 10 replies 6 participants last post by  Trev.B
Hi I have an 87 mk2 polo wit a 1 litre engine nd 4 speed box, have been thinkin bout an engine swap 4 a while nw, d other day i saw a mk1 gti golf engine in the classifieds, an 8v one wit a gearbox and was wondering if anyone knows weither the engine mounts would need much modifying if any at all? Or if there is an easy engine swap I should b considering, for example one that doesnt require any changes to the engine mounts, any help appreciated
easiest and cheapest swap would be a 1.3 with a 5 speed out of a mk3 polo. "big block" engines like the mk1 GTI lump need a special subframe, google "Salzmann subframe", I believe they're very expensive and might not be worth the hassle. I also hear that the "big block" motor in the polo makes them nose-heavy due to the extra weight of the engine..
look out for a complete mk3 polo going cheap and buy the whole thing, that way you'll have everything you need to hand. If you end up finding an engine and box on their own, make sure you get the 5-speed anti-roll bar and gear linkage too, they both bolt-up but are different to the 4-speed items. You'll need the gearbox mount from the 5-speed too. The other two mounts are the same for all engines.
I have exactly that in my mk1 Derby (same as polo), the 1.3 engine is fuel injected so I used the whole loom, tank and fuel lines from the mk3 but if you find a carbureted engine it might be easier on the wiring front. A GT engine would be a nice swap too if you can find one that hasn't been ragged...
Cliff or GSBellew are the local Polo experts
Ha... you seem to know abit too there trevor..
All i can add is - I agree with all of the above..
Single point injection engines are great reliable engines but not ideal if its performance your after.
Must say i highly recommend the GT engine.. They rev lovely.. Nippy enough little car with a few bits.
Full conversions / required bits are always for sale on clubpolo.co.uk and polo3.co.uk for V little also..
Get a good gt if you can afford it and you'll be laughing..
#10 · (Edited by Moderator)
6N polo and ibiza 6K are prob most common / readily available aae motor..
How did I forget the afh 1.4 16v dohc polo 6N engine... Plenty of them conversions being done in England to run on carbs..
Loads of info on clubpolo.co.uk for this.. Nicer looking engine / rocker too..
afh on bike carbs in mk1 polo
Theres also variations like an 1.4 abd bottom end with GT head +injection.. etc... works well and gives a better torque figures than stock GT..
QUOTE (trevorbrady @ Jan 21 2010, 01:42 PM) <{POST_SNAPBACK}>out of interest Gearoid, what cars do the AEE come in?
mk2 caddy pickups and skoda pickups had them too i think
