1 - 9 of 9 Posts
· They're not even a real country anyway
Yep the exhaust has to come out (or if you're a VW dealer, it's just cut
) but then it's pretty straightforward. Well worth doing, it transforms a sloppy grearchange.
QUOTE (Concept @ Jan 17 2006, 04:01 PM) <{POST_SNAPBACK}>Does anybody know how to do gear linkage on a gti. It's the ball and socket part that the gear stick sits into, do you have to take it out from the bottom?
Drop the exhaust ,Remove the heat shield ,Clips up .
undo four 13mils ,i think if i can remember right
,two ten mils hold the ball in place inside the car
QUOTE (fasteddie @ Jan 17 2006, 05:25 PM) <{POST_SNAPBACK}>Drop the exhaust ,Remove the heat shield ,Clips up .
Does anyone know if you can buy these parts as complete repair kits or do you have to buy the links and bushes separately?
Cheers
QUOTE (Glenn @ Jan 18 2006, 11:37 AM) <{POST_SNAPBACK}>GSF do a full linkage kit, not sure if the selector ball is included but they're only a few quid anyway. Most of them are easy enough to fit.
I bought the whole kit from the main dealer for about thirty quid.........totally transforms gearchange from a feeling like stirring watery porridge to positive precision changes!
1 - 9 of 9 Posts
