1 - 3 of 3 Posts
I have one of these if anyone is looking for one.
Rack, pipes, reservoir, pump, pump brackets and the extra pulley for the pas belt on the crank pulley. All pipes in good condition, no leaks from the rack, boots and tie and track rod ends ok also.
Came off a 1.8 8v so will definitely work on any 8v GTI without pas.
I think the belt setup on the 16v ones are different and the pas belt runs on 3 pulleys (water pump as well as the crank and pas pump), anyway this one has the shorter belt and just runs on the crank and pas pump leaving the alternator belt to turn the water pump. Still might fit a 16v though, someone should be able to confirm this anyway.
Price: €200
PM or 086 8548629
1 - 3 of 3 Posts
