1 - 4 of 4 Posts
how hard are they to replace, anyone done it?????? the window is stuck up so cant get it down to take out, any advice?
thanks
ronan
Hi Ronan,
There are 3, 10mm bolts that hold the winder motor in place. If you take these bolts out you can get at the motor to see if you are getting 12volts!
i don't know if you can split the motor from the window mec!
Hope this helps!
i am getting 12v to the motor, i have one on ebay just the motor.... so you think i have to get the whole setup?
was thinking that also as the wire has to go into the moter etc
ronan
I can't remember! I'll look at mine in the morning!
1 - 4 of 4 Posts
