Mk2 Golf Parts
3.3K views 12 replies 7 participants last post by  Mace_Windu
Selling a few bits as i wont be using them on my car after all
8v GTI exhaust manifold. Looks rusty but very solid, good upgrade for your golf driver, improves gas flow. €20
8v GTI downpipe. This is the cleanest used downpipe i have seen for sale Anywhere. I bought it off Geo last year and it was only on the car a very short time. It has no rust and has just been on long enough to become heat tinted which looks cool. Perfect Flex joint and welds. €60
8v GTI complete bosch distributor. Seen very little use, looks very clean, spotless cap and rotor. Can be fitted as a good mod to carb'd golf as it produces a different timing advance curve to the standard dizzy. €50
1.6/1.8 carb inlet manifold. Comes with very good rubber flange, has heater still attached, clean ports and good coolant channel ring. Currently has weber block attached but this can be removed. €30
Weber 54" manual choke cable brand new never used just want back what i paid €15
Weber 32/34 DMTL carburettor. Currently jetted for a 1.8. Has had a service kit fitted on 27/11/07. Very clean inside, butterflies open and snap shut perfectly, new gaskets. Includes mounting block as seen attached to manifold. Comes with new emulsion tubes, spare jets, receipt for service kit from fast road cars, original italian exploded assembly diagram.
The only bad point with this carb is when i bought it the choke was removed. I tried piecing it back together, the choke itself is there but there are some parts of the linkage missing. All the linkage bits i have are included in a bag with the carb. It is unfortunate because it looks so clean. Somebody with some carb knowledge or a spare broken weber would get this working no problem. Can be re-jetted easily. Great upgrade. Has to be worth €50 to someone
For more pics of all these parts here is a link to the album
http://s227.photobucket.com/albums/dd142/Dave46and2/Parts/
QUOTE (Mace_Windu @ Oct 22 2008, 12:27 AM) <{POST_SNAPBACK}>Mike could jet that carb to play dvds id say if ya asked him nice enough!
QUOTE (The Doc @ Oct 22 2008, 12:44 AM) <{POST_SNAPBACK}>Does that Inlet Manifold fit the 1.3?
nope it wont fit a 1.3 atall.....can be used with a 1.3 inlet manifold using the correct mounting rubber
