1 - 6 of 6 Posts
Seem to have a problem with the brake lights on the mk1. They are just not working. Replaced both bulbs and noting. tested the brake light switch on the servo and still noting. not sure which fuses it is as I dont have the owners mannual so if anyone knows would be great if you could tell me.
Is there anything else Im missing thats worth a check ?
Cheers
i have one at home, i will text you the fuse number when i get home if you dont get sorted before then
are all the other rear lights working? It could be a bad connection in one of the connector plugs...
Yeah everything else is working fine. If you could text that number it would be great Rich. Thanks
1 - 6 of 6 Posts
