1 - 1 of 1 Posts
'Black Balled' member
is the ABS light on?...even occasionally? ...if so You will need to do an ABS bleed/purge via VCDS/VAGCOM.
Presumably the front calipers etc are in good nick? Any fluid loss on replacing the lines?? I fit a knackered cut n bunged old brake hose immediately after uncoupling brake hoses on renewing them, especially on ABS equipped cars... if an air-bubble finds its way back to the ABS unit it can cause also sorts of problems...
1 - 1 of 1 Posts
