1 - 3 of 3 Posts
has anyone fitted the powerflex rear wishbone bushes on a mk 2
which way are they meant to pressed in, from the top down or the bottom up?
the instructions that come with them are nt very clear!
They should be pressed in from the top. The bush should also be facing the correct way when fitting it, the two dimples/openings on the bush should be facing towards the wheel (if they are designed the same as OE ones).
no their not the same as the o e bushes those directional markings are, nt on them, ive pressed them in from the top ,thought that was right but ive seen some other mk 2 wishbones the other day and the oe bushes were fitted upside down! might have been replacment replacment bushes fitted incorrectly at some stage though?
1 - 3 of 3 Posts
