Status
Not open for further replies.
I Want My 90bhp Toledo To Chooooooooo:)
36K views 94 replies 47 participants last post by  A.Zdriver
Just wondering about putting a straight through on my toledo. Want a good loud POOOOOOOOOOOOOHHHHH... is this bad for the turbo and whats the best way to do it?? (cut off cat and weld straight pipe or cut off back box, or both??) and will a 90bhp make a loud poooohh?? Think engine code is AGR and iv been told i need a different turbo to make it chooooooooo
Is this true. Has anyone got one on a 90 bhp???
oh ffs
Save
Felt spec
Its his car lads if he wants it to sneeze thats up to him
yes all you have to do is remove the cat and backbox , I bought a car that had this done but i got the backbox weld back on cause it wrecked my head , still made a small sound but it was quicker aswell
Save
But don't bother because as you were already told in your other thread it doesn't work on non-PD engines. Yours is not a PD.
Save
QUOTE (Carden @ Jan 17 2011, 06:40 PM) <{POST_SNAPBACK}>But don't bother because as you were already told in your other thread it doesn't work on non-PD engines. Yours is not a PD.
Walter speaketh the truth...
Save
It does work lad I bought a bora that had that done. Alh engine and the backbox was off. everytime i changed up it made that sound.
pmsl at the pigeon pic
Save
QUOTE (James2.0TDI @ Jan 17 2011, 06:57 PM) <{POST_SNAPBACK}>It does work lad I bought a bora that had that done. Alh engine and the backbox was off. everytime i changed up it made that sound.
Was yours a 90bhp though?? Thanks for the reply btw lad..
Sorry cudn't resist
Save
#16 · (Edited by Moderator)
QUOTE (DarraghB @ Jan 17 2011, 06:14 PM) <{POST_SNAPBACK}>Just wondering about putting a straight through on my toledo. Want a good loud POOOOOOOOOOOOOHHHHH... is this bad for the turbo and whats the best way to do it?? (cut off cat and weld straight pipe or cut off back box, or both??) and will a 90bhp make a loud poooohh?? Think engine code is AGR and iv been told i need a different turbo to make it chooooooooo
Is this true. Has anyone got one on a 90 bhp???If you wire up your exhaust to your horn it'll CHOO POO all night , let me know if it works for you as i've a 1.2 3cyl corsa here i was going to POO all over
BTW tint the glass ,fit RS6's,fit HID's and a really fcukin big sunstrip and it'll finish it off man dude deadly buzz man
QUOTE (Ray @ Jan 17 2011, 08:30 PM) <{POST_SNAPBACK}>If you wire up your exhaust to your horn it'll CHOO POO all night , let me know if it works for you as i've a 1.2 3cyl corsa here i was going to POO all over
Save
#18 · (Edited by Moderator)
stick a pigeon under the bonnet with a piece of string around its neck that runs into the car and is attached to the gear stick, every time you change gear it will yank the pigeons neck and the pigeon will coooooooooooooooo, pharp pharp brrruuuummmmtssshhhhh........
dont pull the string too hard or you'll break the pigeons neck and then you will suffer from what the other pigeons call a pigeon with a broken neck "LIMP MODE"
doesny have to be a pd engine, you need a vnt turbo setup which you dont have if its agr, so you may just forget about it, if you did have the vnt setup all you do is remove the rear box, but your turbo is wastegate type so you cant have that noise
QUOTE (Simon @ Jan 17 2011, 09:24 PM) <{POST_SNAPBACK}>dont pull the string too hard or you'll break the pigeons neck and then you will suffer from what the other pigeons call a pigeon with a broken neck "LIMP MODE"
FPMSL
Status
