Damaged Subframe Nct
1 reading
1.6K views 13 replies 7 participants last post by  GaryO
Couldn't see another section for this.
When the tester couldn't open my bonnet he decided he was pissed off and looked for every loose screw on the car. One of the things he put down was that the subframe was damaged. Now, he put a bit of paint on it, and to be fair it's nothing major.
I'm assuming I can just weld a plate over it? It's about 4cm squared where the "damaged" area is, so if I welded a plate over, gave it a skim of chemical metal and painted it up, I can't see there being a problem, or am I wrong?
QUOTE (ShaunieVW @ Oct 26 2011, 11:49 AM) <{POST_SNAPBACK}>let me guess, just under the wishbone joint onto the subframe, when I put mine through it was peeled back like a tin of sardines, Nothing was said!!
QUOTE (Keith-n @ Oct 26 2011, 11:50 AM) <{POST_SNAPBACK}>Whats the "damage"? Is it just dented from the car being too low?
Pretty much as Shaunie said, it's just pealed back a wee bit in that exact location
QUOTE (colton @ Oct 26 2011, 06:33 PM) <{POST_SNAPBACK}>4 bolts into car,
4 into rack,
3 to remove dogbone mount,
6 on ball joints,
4 on ARB (if you still have it fitted).
total 21 bolts, 1min 48sec's each, no problem
If life was only that easy
I've 240,000 miles worth of shit under the car, I'd imagine there's be a problem somewhere!
QUOTE (GaryO @ Oct 26 2011, 06:35 PM) <{POST_SNAPBACK}>If life was only that easy
i despise your lack of win.
