i have a mk2 jetta and is a tad hi i only want to lower the car a cuple of inches is cutting them a bad idea and how much would u cut off the back an front to make it even ?
if you cut the springs too m,uch and go over a bump the springs wont decompress enough to keep tension at the top of the shock and they will fall out of the home for them at the shock top
go onto ebay, u can get a brand new set of cheap budget coilovers, for all 4 corners, that will drop ur car as much or as little as you want. delivered for about 200quid. cheap easy route in my opinion - alot safer than cut springs and u can pass nct with this aswel.
QUOTE (ven-to-the-o @ Feb 20 2011, 06:14 PM) <{POST_SNAPBACK}>go onto ebay, u can get a brand new set of cheap budget coilovers, for all 4 corners, that will drop ur car as much or as little as you want. delivered for about 200quid. cheap easy route in my opinion - alot safer than cut springs and u can pass nct with this aswel.
thanks its just i dont have the money
is lowerin springs any good how low would u go with springs tat wont be overly bumpy ?
QUOTE (doyle @ Feb 20 2011, 04:32 PM) <{POST_SNAPBACK}>i have a mk2 jetta and is a tad hi i only want to lower the car a cuple of inches is cutting them a bad idea and how much would u cut off the back an front to make it even ?
i've a set a jamex springs here if you want ta make me an offer on them...cost me 120euro delivered...their brand new as never fitted them cause when went takin my suspension out dey were all frigged wit rust...one was even bent...their 80mm drop...
QUOTE (jetta gtd @ Feb 20 2011, 06:50 PM) <{POST_SNAPBACK}>ive a set of lowering springs here lower the car about 60 mil in good nick
i want 60e for them but im in kilkenny
could u post them r they in good nic will they even out ok when in
Related Threads
Volkswagen Automobiles Forum
posts
731K
members
12K
Since
2005
