Cordoba Cupra 20vt
6.4K views 23 replies 12 participants last post by  IbizaSteve
as above am looking for some info on them how rare are they how many were build were they ever sold over here etc.......
QUOTE (vinty @ Jan 7 2011, 07:35 PM) <{POST_SNAPBACK}>Not sure of the details on these. Did ya see the one on done deal? Nice looking car and not bad money. Ya thinking of purchasing?
He already has it
yes i have this car already its a lovely driver ,just has a few things to be sorted out on it but its geting there
ive orderd two new wishbones an ball joints for it off seat as the bushings were fcukd in the old ones,
i had to get a new gasket for the oil line feed that goes into the bottom of the turbo as it was pissing out oil (*fixed now)
i also got a vw dealer to do a full scan on it to see if it brought up anything an it did,
they said theres a split air pipe in it somewere, an theres either one of the n75 valves or the none return valve on its way out
i got them to print out the fault code for me so if anyone can put them into english il post them up.............
i also did a bit of looking around on google for info on them from what i can find it looks like there was only ever a 1000 of cordoba cupra ever made in a 156bhpcupra version an 180bhp cupra r version that came with brembos an a few other upgrades
rare bus.
post up the scan results and one of the guys with vagcom will tell you what they mean, as for the n75 valve, alot of them gave trouble. fix that and the split pipe and she will run a whole pile better.
QUOTE (Razor @ Jan 11 2011, 01:24 PM) <{POST_SNAPBACK}>get ur self a H valve from a 225 TT when u change ur current N75, much better.
The 225 never specifically had the N75H, they seemed to differ
Also, certain car's won't take well to them, if the car is remapped chances are it'll be fine.
If you still have the standard recirculating dump valve I'd recommend upgrading to the forge 007p before changing to the N75H aswell, the boost spike will very quickly find any weakness in it.
QUOTE (J-GTi @ Jan 11 2011, 01:36 PM) <{POST_SNAPBACK}>The 225 never specifically had the N75H, they seemed to differ
shit yeah my bad!!! but johns right get ur self a good DV, the forge smoothed out the boost in johns old cupra after the remap. drove alot better.
its a nice car hearty
fast too
did you find where the oil was coming from ?
QUOTE (jon_95 @ Jan 11 2011, 01:31 PM) <{POST_SNAPBACK}>They are an AYP 156BHP engine, special order in the uk and ireland which was offered to main dealers.
The one you have was ordered for the daughter of the dunlaoighre main dealers and since then I know three of the past owners. She had a new engine and turbo early in life and is one of 5 in rhd. There is another one in dark navy in the country also that was down south when I last heard of it. great little car man, well wearMmm sound for telling me that must check the cam belt etc on it ye i kinda thought that about the turbo cause the old owner had told me there was a k04 fitted with a forge actuator i can see it has the forge actuator on it an there is a very good pull out of the turbo an shane (Mk3McG) can tell you that
..had it up on the lift the other day but i never thought of checking to see if it was
il check when im puting the wishbones in,is there any handy way of telling will it say k04 on it?? sorry im new to the 20vt too use to me n/a old skool cars
was there only ever 5 made in rhd cause the old owner told me there was four in ireland
QUOTE (colton @ Jan 11 2011, 12:52 PM) <{POST_SNAPBACK}>rare bus.
post up the scan results and one of the guys with vagcom will tell you what they mean, as for the n75 valve, alot of them gave trouble. fix that and the split pipe and she will run a whole pile better.FAULT CODES.............................
(1) 16804 P0420 035
catalyst system,bank1
efficiency below threshold
static
(2) 16795 P0411 035
sec.air lnj.sys.
incorrect flow detected
intermittent
(3) 17963 P1555 035
value above maximum charge pressure
intermittent
i no number (1) is caused by what looks like a (custom) decat with no other(center) boxs apart from the back box
any help on these other two would be great
thanks
QUOTE (heartygti @ Jan 11 2011, 11:44 PM) <{POST_SNAPBACK}>Mmm sound for telling me that must check the cam belt etc on it ye i kinda thought that about the turbo cause the old owner had told me there was a k04 fitted with a forge actuator i can see it has the forge actuator on it an there is a very good pull out of the turbo an shane (Mk3McG) can tell you that
If thats the car I think it is this is the actuator - http://www.forgemotorsport.co.uk/content.a...duct=FMACVAG03S
Its a K03.
Keith
#14 · (Edited by Moderator)
QUOTE (Alloy-Wheels.ie @ Jan 13 2011, 11:23 AM) <{POST_SNAPBACK}>If thats the car I think it is this is the actuator - http://www.forgemotorsport.co.uk/content.a...duct=FMACVAG03S
Its a K03.
Keithil be putting it up on the lift later to do a bit of work on it so il have a good look at it then but that looks like the actuator it has
i dont no why people have to lie when selling there car trying too make it out too be better then it realy is
it piss's me off
same crack when i wented too buy me mk2 i was told it had a 2liter 2e bottom which it turn out to be a load of lies, in the end i just fitted 2liter one too it
QUOTE (MannixLacey @ Jan 13 2011, 01:27 PM) <{POST_SNAPBACK}>If it just has an adjustable actuator and the boost is cranked up without a remap I'd doubt it's be the healthiest thing for the engine.Mmmm....... true never thought of this,im just goin to send it up to joe for a remap an see what he thinks an if it turns out that it doesnt have a k04 well then there will be one fitted
QUOTE (Razor @ Jan 14 2011, 01:27 AM) <{POST_SNAPBACK}>fault codes 2 and 3 are related, split in a vacuum pipe somewhere, my vrs threw that up and that was the cause.
Also me7 would kill the boost if it was over boosting, or it should, has it dropped the turbo at all on u?ye the odd time when you drive it hard mosty in 3rd at around 5,000rpm it goes but comes back in after a gear change
QUOTE (heartygti @ Jan 13 2011, 12:34 PM) <{POST_SNAPBACK}>il be putting it up on the lift later to do a bit of work on it so il have a good look at it then but that looks like the actuator it has
it piss's me off
Maybe he passed on what he was told when he bought it, you dont know really. Its in a buyers interest to check usp's before going ahead with any deal.
Keith
QUOTE (Alloy-Wheels.ie @ Jan 14 2011, 04:17 PM) <{POST_SNAPBACK}>Maybe he passed on what he was told when he bought it, you dont know really. Its in a buyers interest to check usp's before going ahead with any deal.
Keith
i was just saying what i was told, i told him i took it as a part exchange and didnt know too much!
and the corrado i swapped for has been sitting in my drive ever since with immobiliser problems and the milage wasnt correct either. so dont go talking about me, i told all knew which you didnt!
QUOTE (liamo14 @ Feb 11 2011, 12:42 PM) <{POST_SNAPBACK}>i was just saying what i was told, i told him i took it as a part exchange and didnt know too much!
and the corrado i swapped for has been sitting in my drive ever since with immobiliser problems and the milage wasnt correct either. so dont go talking about me, i told all knew which you didnt!hold on a f**kn minute
1. the immobiliser never gave me a any problems at all only thing that ever happend on them lines was the car locked it self with the keys in it when it was started an i told an warned you about this....
2.if you looked at the for sale add on gumtree you would of saw it stated that the speedo cable was broke (an you would of seen this when you took it for a test drive )
3.since the speedo cable was broken the car was sitting in a vw main dealers in louth(which your more than welcome too ring) for the guts of 2years, so there was no miles put up on it in that time only miles were put up by me which were under 1.5k
4. the only thing i never told you about was the shit/crapy headlights on the car which im sure you found out for urself an even at that its the same with most corrado's as some of the forum user's on her can tell you that.
5.your comment about "SO DONT GO TALKING ABOUT ME"
...who's gives you the right too stop me telling the forum user's on here what upgrades you told me were on the car.....(fair enough if thats what the old owner told you il take that) but answer me why im not allowed talk about what you told me about it????
6.an your car wasnt 100% either you brought it down too me pissin out oil which i think you were hopeing i didnt notice but i did then you tryed too tell me that you didnt no anything about it but you later said that there was oil all over your drive way/park space an that you had toped it up
end of......
deals done now
QUOTE (heartygti @ Feb 14 2011, 09:16 PM) <{POST_SNAPBACK}>hold on a f**kn minute
end of......
deals done now
i never checked the gumtree ad cause you rang me about the swap, so fair enough i should have checked it.
i did tell you all i knew about that car thou, if i knew it had those problems i wouldnt havnt even bothered showen you the car.
not on this to rip anyone off or make any enemys, just got a bit bothered when i read you said i lied.
good luck with the car, didnt mean to slander you there.
