Buying A 944 What To Look Out For?
3.9K views 4 replies 5 participants last post by  B2AUDI80
Ok so I have been thinking of getting one more car,
and saw a 944 at a vintage show and quite liked it even got a spin in it. Let it be said I'm not stupid just cos I see something I want one, was looking at getting a 928 for a long time but the 944 just took my fancy never got to see both cars parked beside each other till now.
I understad the a lot of audi wiring and parts are interchangeable with them.
I first started off looking at the 928 for the simple reason that it seemed cheeper and had the same block and engine layout as vw
so in short, what doi look out for in looking to buy a 944? I'm guessing rust and any knocking sounds? What else, and where are the common places for rust, are parts easy to get what engine sizer are there I won't be going for the 3lt as I want to have some money left the 2.5lt would be grand is there a 2.0 lt? What else should I look out for?
And what would I be expecting to pay for a good one, ready to drive?
Or one which would require some work?
Ill have to consult the father now but Im nearly 100% sure that the 944s were all galvanised. Ive driven the 2.5na and it was pretty cool, savage driving positon.
If it were me, Id be goin for the 924 turbo series 2. 2ltr turbo and a much lighter body than the 944.
the 944 engines were totally porsche engines so parts/servicing will be far more expensive than the 924 which is essentially a vw block and porsche head etc
Ill talk to the father, he'l know beter....I'm just trying to remember his ramblings
They were galvanised. But check for rust along sills due to careless jacking.
Theres nothing really major on these compared to any other car so check all the obvious stuff like popups work, rear wiper works, switches, etc. A lot of these parts are still pretty cheap though so they can be replaced if faulty.
Check the gearbox in all gears incl reverse and take a sharp turn to check diff for any noises.
The 2.5 engine has balance shafts, if it feels rough they may not be timed correctly, Ive done 2 belts on these and the two were set wrong on pulling them apart.
Some also removed the shafts for more power, but thats rare.
If your not sure of timing belt history drive it home easy and change it asap. The belt is stressed more-so than a normal one because it has teeth on both sides, each side is doing something always.
The biggest pig of a job you can do on these, and the only one that might* turn me off buying one is if the torque tube bearings are gone rough. You'll hear them when cruising under your left elbow. There four bearings in the tube that support the shaft back to box and they are a big'ish job to change. But, they are normal sizes and can be got off the shelf for around 8euro each, the real cost is the time needed to fit them.
In addition to the above good advice from the lads you'll find a wealth of helpful owners on the Porsche Club forum in UK and here in Ireland.
