The back axle is slightly off centre on every fwd VW. It's only when you lower them significantly that you notice this. You can get the axle centred by a competent tyre place that does alignment, all they have to do is loosen the bolts holding the axle to the chassis and tap it over a couple of mm, or you can do it yourself if you're any way handy.
