Can anyone help with the below code?
It happend when I replaced a nicked a fuse for my MK4 GOLF
When I replaced the 10A fuse and fired betsy up it threw back an emissions warning fault. I have to admit I pulled a few 10A fuses but all have since been replaced. Ran the diagnostics and cleared all fault codes but the car is still down on power, the car may even be in limp mode. Any suggestions? Disconnect the battery for 15 mins etc
Oh there is an original tunning box fitted!
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 B HW: 028 101 147 8
Component: R4 1,9L EDC 0000SG 5645
Revision: 12345678 Serial number: VWZ7Z0D9700538
Coding: 0003031
Shop #: WSC 00000 028 00001
VCID: 2241720B845F
1 Fault Found:
18000 - Altitude Sensor / Boost Pressure Sensor: Implausible Correlation
P1592 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Bin. Bits: 11000000
Absolute Pres.: 1009.8 mbar
Absolute Pres.: 1173.0 mbar
Readiness: 1 1 0 0 1
Coding: 0003031
VCID: 2241720B845F
1 Fault Found:
P1592 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Bin. Bits: 11000000
