My sister's 1999 1.4 is pretty much on it's last legs. It's done 120,000, sounds like a diesel and it's burning gallons of oil
Does anyone know anything about this silent recall they had
this
QUOTE I really don't mean to be a doom monger but my Golf 1.4 needed a new engine after 8000 miles! It had always sounded pretty rough but it started sounding more and more like a diesel, especially when cold. It was most noticeable under load first thing in the morning when it had a pronounced 'knock'.
When I took the car to my dealer, I had barely finished describing the problem when the foreman said that it will need a new engine. As you can imagine I was horrified. Apparently there is/was an issue with certain 1.4 16v engine losing a teflon coating on the pistons which causes the pistons to 'slap' resulting in the noise I was hearing - at least this is what I was told. VW was aware of the problem and was replacing engines as soon as somebody reported the issue rather than recalling cars which would be hugely embarrassing for them.
Apparently my 2000 model car was one of the last to be affected by the bad batch of pistons so your 1999 car could well be suffering the same problem.
and
QUOTEFirstly, a degree of piston slap is normal for the 1.4/1.6 16v engines when cold. This is because the forged pistons expand at a different rate to the alloy block and therefore have to be slightly undersized so as to not seize the engine when hot. Hence when cold the piston strikes the side of the cylinder sideways before travelling downwards creating the hollow knocking sound which is referred to as Piston Slap. This noise should disappear quickly as the engine warms.
VW had a silent recall on early MK4 Golf 1.4's because teflon coatings on the pistons (which are supposed to minimise the effect of piston slap when cold) were wearing away prematurly causing a worsening of the piston slap. Obviously, engine replacements are not particularly good press and the problem appeared to have been kept very hush hush. I had the engine in my 2000 MK4 1.4 replaced because of this and it was apparently a very common fault.
